place External Drawing vs Attach Xref. about the Pen settings.
1. I would like to know about place External Drawing.... vs Attach Xref.
What's the difference between the two?
2. I want to know about the Pen settings.
There was no problem with merging...
Both don't seem to be set up.
AC25 5010 / AC26 4019 on window 11
1 REPLY 1
2-1. I don't know what the view translator does in xref manager.
No matter how much I change it, nothing changes.
Even if you change it in the dxf-dwg translation setup, the input xref has no effect.
In other words, detach the xref and call it again, it seems to be resolved.
is this the correct answer?
2-2. What comes in attach xref is an object that cannot move and is used where?
3-1.  omg!
Suddenly, place external drawing... changed the pen. ^^
obviously didn't...
Turn it off and turn it back on to see if it works.
It must be a bug. ^^
