Design forum
Window surrounds, cills etc
What is the best way to model window surrounds, cills etc please?
In Revit, I'd create parametric families (multiple repetitions/variations of) or model in place (one off instances).
I'd had a brief look at this from the NBS but not dived in until I'd done a little more in archicad:
https://www.nationalbimlibrary.com/library-part-maker
Attached is the front elevation to give an indication of what I'd like to model
10 REPLIES 10
I don't see your attachment, but depending on level of detail needed I either use the options availabe in the door and window objects for sills, lintels and trim and what not.
If these fall short of what I try to achieve, I will sometimes us complex profile walls/beams/collumns/slabs on a separate layer with a different intersection group number of the layer that the wall hosting the door/window is on (to avoid unwanted intersections).
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thanks for your reply Erwin, the image should be attached now.
Is there an option within the window families for stone and/or brick cills? I used the tool for adding a stone head but the cill seemed to relate to the cill of the window.
Not sure about the options for your library, but you might have some luck using the jamb / casework option on the outside to mimick what is needed. If it needs to be 'fancy', I would probably model these seperately.
www.leloup.nl
Windows 10 Pro
There are also some objects you might use for this in the object library, but they might be limited in what you can achieve.
www.leloup.nl
Windows 10 Pro
Thanks. I'm completely new to creating anything from scratch in archicad.
Can you create an object and save it for repeat/future use or do I need to learn about GDL?
You can save anything as an object (2D fills, lines, 3D elements) or as a module.
Given the picture you shared, if you are re-creating the building for a renovation, I would say the repeating isn't that much, so you might opt for just copying the elements around so you can adjust on the fly.
www.leloup.nl
Windows 10 Pro
If you don't have objects to do these sort of surrounds, then you could possibly make them with morphs directly on the elevation/3D model.
Or probably easier to create them with complex profile walls or beams in plan (lying flat).
Also use slabs, roofs or other tools to get the shapes you need.
Then convert to morphs (edit some more if you need to), rotate to stand them up and reposition them to where they are needed.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Thanks to you both (especially for the summary of options/alternatives Barry), I'll try those out and see what works out best.
ARCHICAD has a full playlist of 55 clips on YouTube that is about object creation:
https://www.youtube.com/playlist?list=PLF7F4FC644EFC4889
I think if you watch the whole playlist and follow the exercises, you will be pretty knowledgable about it by the time you get to the end of it.
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Appreciate you pointing me in the direction Laszlo.
Didn't find the answer? Start a new discussion
Labels
