Developer forum
Questioning about manuals ?
Nader Belal
Mentor
Where is the place that I can propose the editing for manuals ?
For instance, right now, when revising COOR, COOR{2}, COOR{3} GDL commands, there was no mentioning that the these take effect after defining a specific body.
Well you have mentioned it here - someone from GS may pick up on it.
Or you could try the GDLCenter Forum ... http://gdl.graphisoft.com/forums
That is monitored more by the GDL guys from Graphisoft - at least they reply more there than they do here (for GDL problems).
Or send a support ticket to your local Archicad support people.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
80 REPLIES 80
Versions 6.5 to 25
Nader Belal
Mentor
Thank you @Barrey
Nader Belal
Mentor
@Barry
here it is
http://gdl.graphisoft.com/forums/topic/proposition-about-gdl-reference-manual
You can also make your further suggestion in this thread and I will report them to GRAPHISOFT for their consideration.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Nader Belal
Mentor
@LaszloNagy
Here are they:
Yes, I have seen that and I will forward that to GRAPHISOFT.
I was talking about further/additional suggestions beyond the one you already wrote in that post.
Nader Belal
Mentor
Ok, I will take this advantage to write down few things:
Manual:
1. Style: for Variable names, insert "bmat" for building materials (page 494)
2. Connection with Grasshopper, I think it's time that Graphisoft include snippets examples for GDL that is controled by Grasshopper, instead of mentioning it in Grasshopper manual only.
3. Nurbs, the examples that are mentioned in the manual is quiet obscure, better & clearer examples should be set.
4.Radial graphical hotspot, type 7 is not clear where it's place, beside, the example that is drawn should be shown in 3D, and not in 2D only.
5. Object Migration, snippets must not only mention what they do but how, may be as comment in the examples that comes in the manual.
6. GDL debugger, must be included in the manual with careful instructions of how to use it with examples.
Thanks, I will forward also these to GRAPHISOFT.
Nader Belal
Mentor
@LazloNagy
7. Examples for cutplane{2} is deficient
Nader Belal
Mentor
@LazloNagy
8. PROJECT2{3} needs examples
http://gdl.graphisoft.com/tips-and-tricks/explore-the-project23-command
The example object used is available in the link at the start of the page.
Ling.
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Win10 | R5 2600 | 16GB | GTX1660
Nader Belal
Mentor
And that is why it should be included in the manual
Nader Belal
Mentor
@LazloNagy
9. Some neat tricks related to GDL creation would be nice.
For example, the difficulty of using cutpolyA (& variants) is that there is no direct way to see them in the GDL 3D preview, but you can write this for the manual (as an example😞
Tips & tricks:
Working with CutpolyA (and variants) can be a little difficult to use since that there is no direct way to see them, especially when they don't give you the result that you wish.
But modifying the code to be prism_ compliant then by commenting the first line as seen in following example can make your work process a lot more easier ...
!cutpolyA 4, 3, 1,
prism_ 4, 1,
0.5, 0.5, 7,
0.75, 0.5, 7,
0.75, 0.75, 7,
0.5, 0.75, 7
Moonlight,
You do not need to address your posts to me, it is enough to post them in this thread. I have forwarded it to GRAPHISOFT,
Nader Belal
Mentor
Done
Nader Belal
Mentor
@LazloNagy
This note should have been included in the GDL manuals
https://archicad-talk.graphisoft.com/viewtopic.php?p=11333#p11333
Nader Belal
Mentor
By the way CWALL_ command doesn't even have a tiny whiny lousy example, and in the forums there is only 4 entries, being 1 as moderately related.
Nader Belal
Mentor
NON GDL Side Note
Graphisoft should start to ship it's API manuals as PDFs (2 to be accurate):
1. One for reference.
2. Second for first steps using API
Ralph Wessel
Mentor
The API reference documentation is fine the way it is:
- It comes with linkage to VS and Xcode (for interactive use)
- It's far quicker to open a small document for the info you're interested in (a PDF with the API reference would be enormous)
Is there some specific advantage you're seeking from a PDF?
Ralph Wessel BArch
