Project data & BIM
Restructure Table Gap - Schedules
JCCARLOS91
Whenever I "restructure table" my schedule on the layout, it leaves a big gap between rows. I am at a lost as I feel that there should be an easy fix but can't figure it out.
John Carlos
AC25 | iMac 2019
4 REPLIES 4
RandyC
You know you can double click the lines and they will adjust the columns / rows automatically
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Hi Randy,
Thanks for the response but this is not what I meant.
My apologies. i thought I have attached the screenshot. Anyway, here it is.
The issue is on the sheet itself. I know I can crop and stick them on top of each other but that doesn't seem very efficient.
John Carlos
AC25 | iMac 2019
cmorel
Does anyone know a fix or explanation to this?
It happens often, and aside from removing and re-dropping the schedule on the sheet, I have not found a satisfactory explanation for this bug.
Caroline
AC 19 - 27 USA
OS Sonoma
MacBook Pro - 32GB
I have not come across this issue.
Does it help if you restructure and change the width of it again?
Or no matter how wide you 'restructure' it, it will always have those large gaps and you always have to re-place the schedule view?
