2022-11-18
06:28 AM
2023-05-20
12:20 AM
Gordana Radonic
Whenever I "restructure table" my schedule on the layout, it leaves a big gap between rows. I am at a lost as I feel that there should be an easy fix but can't figure it out.
2022-11-18 09:42 PM
You know you can double click the lines and they will adjust the columns / rows automatically
2022-11-21 05:00 AM
Hi Randy,
Thanks for the response but this is not what I meant.
My apologies. i thought I have attached the screenshot. Anyway, here it is.
The issue is on the sheet itself. I know I can crop and stick them on top of each other but that doesn't seem very efficient.
2023-06-16 11:16 PM
Does anyone know a fix or explanation to this?
It happens often, and aside from removing and re-dropping the schedule on the sheet, I have not found a satisfactory explanation for this bug.
2023-06-19 05:08 AM
I have not come across this issue.
Does it help if you restructure and change the width of it again?
Or no matter how wide you 'restructure' it, it will always have those large gaps and you always have to re-place the schedule view?
3 weeks ago
I had the same problem in some of my schedules whenever ALL the columns were resized to fit content. Once at least one column was resized manually, all came back to normal. Hope this helps.
