Project data & BIM
Restructure Table Gap - Schedules
JCCARLOS91
Whenever I "restructure table" my schedule on the layout, it leaves a big gap between rows. I am at a lost as I feel that there should be an easy fix but can't figure it out.
John Carlos
AC25 | iMac 2019
7 REPLIES 7
RandyC
You know you can double click the lines and they will adjust the columns / rows automatically
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Hi Randy,
Thanks for the response but this is not what I meant.
My apologies. i thought I have attached the screenshot. Anyway, here it is.
The issue is on the sheet itself. I know I can crop and stick them on top of each other but that doesn't seem very efficient.
John Carlos
AC25 | iMac 2019
cmorel
Does anyone know a fix or explanation to this?
It happens often, and aside from removing and re-dropping the schedule on the sheet, I have not found a satisfactory explanation for this bug.
Caroline
AC 19 - 27 USA
OS Sonoma
MacBook Pro - 32GB
I have not come across this issue.
Does it help if you restructure and change the width of it again?
Or no matter how wide you 'restructure' it, it will always have those large gaps and you always have to re-place the schedule view?
me_arch
I had the same problem in some of my schedules whenever ALL the columns were resized to fit content. Once at least one column was resized manually, all came back to normal. Hope this helps.
This is AC bug that happens very randomly till most recent AC 28 versions. Changing column's width helped to fix issue, thanks @me_arch for good tip 😉
For me also it happens to Window / Door schedules.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v28 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
runxel
Hero
@James B might be interested in this.
Does this still happen in AC 29 for you?
