Wall labels from .mod file
Is there a way to label a wall in a team work file if the wall is part of a mod file?
(If I label the walls in the mod file a lot of the labels will overlap with labels of other walls from other mod files)
4 REPLIES 4
schagemann
unfortunately this does not work and you rely on coordinating where your labels live.
btw. we typically keep only internal walls, e.g. all walls inside an apartment in our mod files and all party walls in the main / master file where the apartment mods get referenced into… which assists with label placement and avoiding clashes.
macinteract
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
What do you mean by "mods get referenced" ?
schagemann
please have a look here...
http://archicad-talk.graphisoft.com/viewtopic.php?p=225488#225488
link's videos pretty much explain the principle.
macinteract
Thank's for the reply!
