2D Fills in 3D documents
Hi:
Is there any way to see 2d fills in 3d documents? I draw them but all of them are empty.
It this an override I'm missing?
Could be a Graphic Override, which sets the Fill Type of Fill elements to Solid or transparent?
I checked the default ARCHICAD Template File and several of the default Graphic Overrides will cause this effect. So if you activate a Graphic Override or a saved View in the 3D Document Viewpoint, it can modify how your 2D Fills are displayed.
