Patrick M
Ace
3d document - measure/tracker values
When I take a 3d document of a cabinet, intending on annotating it with sizes, panel layout and assembly directions... the measure function gets really weird.
This cabinet is NOT 21'-9 1/2". This is a 3d document straight from the model. Why does the view scale impact the value in the tracker? Seems nonsensical.
Setup info provided by author
2 Replies 2
runxel
In a 3D document you will no longer measure real dimensions with the tracker or the quick measure tool. In fact, the measurements will be all "off", but they won't change if you change the scale.
I think this basically stems from the crude way the 3D doc is generated internally... (like pixel space becoming model space or something like that)
jl_lt
Ace
This is one of the things that SketchUp handles great and much better than archicad, the ability to anotate in perspective (still not good enough reason for using that software).
If I remember correctly, using isometric 3d documents instead of perspective can help you get real measurements.
