2020-05-07
09:37 PM
2023-05-30
09:55 AM
Rubia Torres
2022-12-09 03:52 PM
First time experiencing this issue and we are using Norwegian version of AC 25. Using 5010 NOR FULL version of archciad 25. I hope it wound not spread to other procjects😖
2022-12-11 02:12 AM
It may be related to 'Ignore zoom and rotation when opening this view' being checked in the 2D/3D document settings in the view settings. A few weeks ago I unchecked it everywhere on a file that was having the issue and haven't had it since.
2022-12-11 11:48 PM
i actually thought the opposite.
its always been (what i thought was a good) habit of mine to never leave that box checked for all Elevation / Section / Internal Elev view -- that way i zoom straight into the building.
perhaps it's because we have half of our projects requiring to be modelled kilometers away from Project Origin (pre-Native Survey Point AC22 project files) that this error would occur. but even with the other team in our office who model at Project Origin, this occurred a lot & with the change to AC25, especially in the early weeks, this was pretty rampant. at its peak, it happened 2/3 times a week. the fix i found was to, begrudgingly, check the Ignore Zoom box. the error only occurs rarely nowadays (still does, but not as much as before). I'm not really convinced checking the Ignore Zoom box has anything to do with it, but the anxiety of opening rotated Elevation / Section / Internal views is too strong & that i have leave the box checked for fear of spending almost half an hour fixing teamwork files using the Open/Repair method.
2026-01-02 05:01 PM
I think I solved it (maybe - works for me):
You have to make section on plan in unrotated project map, not on plan in rotated view map.
3 weeks ago - last edited 2 weeks ago
6+ years later, bug still there in AC27.
Is it somehow related to the view orientation (rotation, that is) data not being accesible to the drawing title object (not accessible as “drawing-level metadata”, says Claude)? In that case it would be two birds with one stone, given a stone.
2 weeks ago
@Ignacio Azpiazu wrote:
3+ years later, bug still there in AC27.
Unfortunately the bug will always be there in 27 now, as it is no longer updated by Graphisoft.
The question is, does it still happen in newer versions?
If so then it should be reported as a bug again.
