‎2006-06-09
08:13 PM
‎2023-05-26
02:35 AM
Gordana Radonic
‎2006-06-10 06:06 AM
Brad wrote:Is your drawing frame set to Fit to drawing?
In plotmaker in the Drawing Settings of the drawing you could select your preview on layout to be vectorial, bitmap, or frame only. In 10 when I move my drawing I seem to be locked into a Frame only view of my drawing in my layout. This makes it difficult to place the drawing since I can't see the contents. Can someone tell me where I can find the setting to make the view live (the old vectorial or bitmap setting) so I can see my drawings while I move them.
‎2006-06-11 11:25 PM
‎2006-06-12 06:10 PM
Archi wrote:Could you elaborate a little. When you indicate that you find this button on the right side, I am not sure on the right side of what you are referring to. Thanks....
You must actualise your view as actual window-view. It takes just seconds.
You find this button on right side.
‎2006-06-12 07:31 PM
‎2006-06-12 09:04 PM
‎2006-06-12 11:51 PM
You have navigation preview, and left edge you can controll zoom and right bottom you can click the button, and on the bottom you can select "new drawing preview (or similar..)"With all due respect, I do wonder about this mate. I didn't think you could use the Navigator to preview layouts, let alone address a loosely related problem such as seeing the drawing's contents during any kind of move.
For big projects it is very nice function, it works very good for layout too.
‎2006-06-13 01:00 AM
‎2006-07-06 05:06 PM
‎2006-07-06 07:39 PM
Link wrote:This is true, it has stepped backwards onto the wishlist.
I believe viewing the drawing's contents during a move is simply unavailable in AC10, whether by design or not.
