AUTOMATIC NUMBERING ON FLOOR PLANS
How do I make sure the automatic numbering on my floor plans is set up ?
Is there an automatic label i need to place in the master title block ? or any other way to do this ?
Thx
5 REPLIES 5
Exactly what type of automatic numbering are you trying to do?
What types of elements?
On Floor Plans, Section, Elevations?
What should the format of the numbers be?
The more info you give, the more likely we can help you.
The floor plan numbering only - i.e. the drawing number
Laszlo,
any more on this?
I basically just need consistent dwg numbers on my title blocks.
So when publishing sets, the numbers change automatically. For some reason the link or thread in doing this has somehow been lost as my pages no longer have the correct numbering after a new sheet is published.
Just need to have drawing numbers change automatically. I don't believe its just a case of having automatic text in th tile block on the master layout, or is it ?
Lingwisyer
Guru
You want your drawing number to change when you publish? Does it contain the revision number or something as a suffix?
I am still lost on what is supposed to be changing...
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
