License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Add ability to easily excluded layouts from the cover sheet index
Professor Pickle
We can exclude drawings and layouts from ID sequences but there is no way to exclude layouts from the cover sheet index. This should be a Boolean property of the layout so that other tools, such as indices can use it to control whether the layout appears or not in the given index.
Pushing the boundaries of local time/space continuum since 1972.
Archicad 26 | iMac (Retina 5K, 27-inch, 2017) | 4.2 GHz Quad-Core Intel Core i7 | 24 GB | Radeon Pro 580 8 GB | macOS 12.6
You have Criteria when defining a Sheet Index.
Just define a criteria that excludes certain Layouts based on one of its available parameters.
1 REPLY 1
