2022-11-24 08:08 AM - edited 2022-11-24 01:17 PM
hello, I would like to ask for your help and opinion regarding the problem experienced by a user.
For example, when we want to drag an object 350 cm, Archicad do it 350, and deletes the number 3 and applies the process as 50 cm.
or we want to draw a wall 680 cm long. but it removes the number 6 and treats it as an 80cm long wall.
This problem is experienced on mac device.
Thanks for your help
Solved! Go to Solution.
2022-11-24 08:30 AM
I am assuming you have Ventura operating system?
If so, it is a known problem with Ventura.
https://community.graphisoft.com/t5/Setup-License-articles/macOS-13-Ventura/ta-p/359447
2022-11-24 08:30 AM
2022-11-24 10:31 AM
as always, include your Archicad version and build, as well as the base computer specs, in your signature...
2022-11-24 11:39 AM
I haven't noticed this issue in AC26 on Ventura but I do have my tracker set to always on, so not sure if that may affect it.
