‎2018-08-07
09:06 AM
‎2023-05-22
11:54 PM
Gordana Radonic
‎2018-08-07 11:43 AM
‎2018-08-08 03:46 AM
LaszloNagy wrote:
Have you tried to change Calculation Units in the Options > Project Preferences > Calculation Units & Rules Dialog?
‎2018-08-08 09:10 AM
‎2018-08-08 10:09 AM
‎2018-08-14 10:08 AM
‎2018-12-12 03:37 PM
‎2022-02-09 03:36 PM
Did you manage to find a solution for this?
I'm trying to auto text some of the openings and Autotext is the only option that gives me the desired values but it does it with some extra decimals which I don't need.
‎2022-02-09 04:05 PM
Have you tried changing the calculation units as Laszlo suggested early in this post?
But that will affect all calculations - i.e. schedules too.
Otherwise you need to create a property with an expression that will calculate a value with the required units and decimal precision that you want.
Then autotext that property in your label.
‎2022-02-09 04:15 PM - edited ‎2022-02-09 04:17 PM
Hi, thanks for the quick reply.
I don't know if this is the right thread but this is the closest one I could find to my problem.
In the attached screenshot with green, you can see what I want my autotext to say, and with red is what it's showing right now.
Hope this helps
