2025-02-05
02:40 PM
2025-07-16
12:05 PM
Molinda Prey
To whom may it regard,
I noticed that when I try to fiddle with Show on Stories - Custom Settings in the Mac version of Archicad (tested on AC 26-28, macOS Ventura 13.7.3), and try to input any number, it doesn’t change.
Have any Mac users had a similar experience?
Stefan Veselinović
Operating system used: Mac Apple Silicon 13 Ventura
Solved! Go to Solution.
Tuesday
The problem seems to be when this Custom dialogue is opened from the Info Box (on Mac), from the Element Settings it seems to work as expected.
We've identified the root cause of it, and working on a fix - however we missed AC30 as that is in final stages of testing.
2025-04-18 05:01 PM
I'm having this same issue. Any resolution?
2025-04-18 05:48 PM
Works fine for me on Sequoia 15.4.1 with 28 as well as 26 - at least with roofs. Tabbing between the fields works too.
Of course, 28 is not officially supported by Ventura... but you say this happens in 26 and 27 which are supported. What type of element(s) do you have selected when you select the Custom option? Are they locked or part of a group? Have you tried starting a fresh project from a template and simply placed a roof and checked the custom settings for it (in a project with multiple stories above/below)?
2026-03-02 12:22 PM
same problem here. any resolution? AC 27 (MAC STUDIO - macOS Tahoe version 26.3)
Tuesday
Tenho o mesmo problema e está impossível de trabalhar!
Preciso de solução urgente!
AC 29 - atualizado
Macbook Pro - macOS Tahoe version 26.6.2
Tuesday
Wednesday
So maybe 3001?
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
Wednesday
@Lingwisyer wrote:
So maybe 3001?
Is that version 30 - build 3001 - i.e. first update.
Or version 3001 - i.e. in a few thousand years time?
Wednesday
A few thousand years time... Barry being such a pessimist. 😂
yesterday - last edited yesterday
Or he is wildly optimistic - hoping he would still be alive at that time, like Mathusalem. 😀
