Bug in text alignement in AC21
Hi
i use archicad 21 rev 3005 FRA 64bits on windows 7
their is a bug with the alignement in text and labels (show attachement)
8 REPLIES 8
gpowless
I've found it is the result of the leader line position to the text.
Select the labels & change the leader line position to the bottom and then back to the position you want. That should fix it for a work around.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
I'm running into the same problem. Using the text label tool and the text tool, it seems that the text box and associated leader is narrower than the actual text.
This popped up migrating project files from AC19 to AC21 (the text was correctly formatted in AC19).
Is this a bug, or is some setting off? Any ideas?
Katalin Borszeki
Hi All, this is known issue, we have had several reports about it. It pops up in different circumstances...there could be different issues present:
1. Displacement can happen on the 4K monitors after scaling.
Workaround: it is recommended to use the 100% scale, it is ARCHICAD's limitation for now. There is an ongoing project about this issue, to make ARCHICAD compatible with 4K monitors.
2."Override high DPI scaling behavior" function on Windows machines
In case of using "Override high DPI scaling behavior' is set for ARCHICAD, it will give incorrect displacement of the text.
Workaround: Right click on the application->properties->compatibility tab and switch off this option before reopening ARCHICAD to apply the settings.
3. Windows 7 with Nvidia Quadro FX 3800M video card.
Workaround: currently, none
Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
alemanda
Me too ...
I'm working on WIN7 and texts have the issues noted before.
I have a 2560x1440 monitor with Nvidia Quadro K620. I Installed latest drivers but get the issue regarding the text alingment ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
I upgraded to Windows 10 and the problem disappeared.
alemanda
Yes, me too.
AC27 latest hotfix
Win 10 Pro 64bit
Steve Jepson
ArchiCAD 21
I also have a problem with display text alignment (center & right):
DELL Precision M6600
CPU Intel(R) Core(TM) i7-2920XM CPU @ 2.50GHz, RAM 24,0 GB
NVIDIA Quadro 5010M 4096 MB GDDR5
driver 21.21.13.6909
res: 2560 x 1080 x 60 Hz (LG 34um68)
Microsoft Windows 10 Pro 64x
v10.0.16299
Microsoft Windows 7 Pro 64x
v6.1.7601 SP1
