roman19
Can't rename Interior Elevation
Hi all,
For some reason the individual interior elevation won't inherit the Name defined in the parent IE Group’s settings.
It is set to “By IE Group.”
Please see a screenshot where I compare both ArchiCAD 26 and 27.
It works all fine in 26. It doesn't work in 27.
It shows correct name under "Name", but incorrect under "Reference to"
Any suggestions anyone?
AC8.1 - AC27
macOS Monterey, version 12.7
Chip Apple M1 Max, 32GB RAM
23 Replies 23
KatherineC97
I'm having this issue too, have you found any solution? Because I'm also unable to change custom names or change the horizontal range it will also just revert back to the previous setting
roman19
No, I didn't find any solution at the moment. I'm curious if this is a Mac issue. Do you have Windows or Mac? (Mine is Mac). Thanks.
AC8.1 - AC27
KatherineC97
I'm working on windows, so it might just be a bug which is very annoying
Sabrina
Hi!
Did you end up finding a solution for this issue? As it is happening to me as well on both the mac and windows computer. I contacted support who asked me to do a preference clean, but that did nothing to solve the problem.
rickedwards6
Same issue. Spend forever trying to problem solve to eventually submit to googling the answer, to find a thread with the dilemma, but no resolution! BUH!!
James B
There is a fix in AC27.2.0 around this issue - and indicated in the release notes.
Let us know if you still experience after updating. Thanks.
James Badcock
AllanP
There is a new hotfix that fixes the problem released 26/03/2024(today...or yesterday if you are in Australia)
https://graphisoft.com/downloads/archicad/updates/archicad-27-2-0
but the crazy text that displays wrong on layouts, but ok when you publish PDF's  is still not fixed
(layout view)
(in the PDF)
hotfix 5003
also,
the decimal point alignment gets broken in schedules with the new hotfix.
(in Archicad)
(in a PDF)
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
tomyg
Amazing!
cocoloco
I have the same issues and this is 2024 in Jun! I am on MacBook . Any fixes?
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
