Eric Milberger
Cannot change the name in a room lable
How The  H.LL do you change the room names on the room label. waited all morning on what should be stupidly simple'
I can see the label on the plan AND I CANNOT Change the name of the room
Eric Milberger, Architect | Master Planner
2 Replies 2
The label gets its information from the zone (or any other element a label is attached to).
So select the zone and change the name in the info box or settings for that zone.
Lingwisyer
Guru
Maybe make a wish for the ability to select associated element(s). In this case it would help selecting the Zone via the Label as there maybe elements above them meaning that you need to cycle selection, or they may even be on a layer that is turned off. The annoying label bounding box is also the easiest thing in the world to select...
Ling.
