2009-09-17 03:20 PM - last edited on 2023-05-26 02:31 AM by Gordana Radonic
2009-09-18 12:47 AM
2009-09-18 01:07 AM
2009-09-18 02:52 AM
2009-09-18 05:20 AM
Peter wrote:Thanks, fixed.
(S2art - your image doesn't work!)
2009-09-18 10:50 AM
2009-09-30 09:46 PM
Keith wrote:Keith, i'm experiencing the exact same problem! I published some pdf's that overwrote the old files having the old name. I use a numbering system where the layouts have a numbering where the last digit is the revision number (starting from 0 etc) For example 1234-0 then 1234-1 etc. So when the publishing window starts it reads "Publishing 1234-1.pdf" but then on the folder there is the 1234-0.pdf but with the content of 1234-1.pdf, esntially erasing the old pdf file.
Our problem is that, after having done this, when publishing the layout, the resulting file sometimes has the original name (the one that it had when first published), rather than the new name, thus over-writing the previous revision of the published layout.
2009-10-01 10:26 AM
2009-10-01 05:43 PM
2009-10-02 09:43 AM
