‎2025-06-05
03:48 AM
‎2025-07-16
11:47 AM
Molinda Prey
The Keynotes tool needs to be able to combine multiple notes into a single label like CI Tools.
Has anyone figured out a way to do this?
Solved! Go to Solution.
‎2025-06-07 09:27 PM
As keynotes work through autotext, when you double click inside a label to edit it, you can add as many keynote datas from as many keynotes as you need. From the keynote button on the text editor.
‎2025-06-07 04:27 PM
I don't think it is possible to do. You would probably have to do some copy-pasting in the Keynote Manager to combine multiple Keynotes into a single Keynote.
If this is a functionality you want in Archicad, you might want to submit a wish on the Wishlist:
https://community.graphisoft.com/t5/Wishlist/idb-p/wishlist
If you do, please post its link here.
‎2025-06-07 10:26 PM
Thank you, James. I must have missed that button! I'm used to Keynote labels not actually being live like that.
I like it; it opens up additional opportunities to add supplemental text!
‎2025-06-08 11:25 AM
Sorry, I see my previous answer was incorrect. I misinterpreted your post and thought you wanted to make a single Keynote out of multiple Keynotes in the Keynotes Palette.
‎2025-06-08 02:34 PM
No, I don't see the need to do that (yet). Combining multiple keys into one label was my need. Thank you both for the help.
