Combine Multiple Keynotes
The Keynotes tool needs to be able to combine multiple notes into a single label like CI Tools.
Has anyone figured out a way to do this?
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
James B
As keynotes work through autotext, when you double click inside a label to edit it, you can add as many keynote datas from as many keynotes as you need. From the keynote button on the text editor.
James Badcock
Graphisoft Senior Product Manager
5 REPLIES 5
I don't think it is possible to do. You would probably have to do some copy-pasting in the Keynote Manager to combine multiple Keynotes into a single Keynote.
If this is a functionality you want in Archicad, you might want to submit a wish on the Wishlist:
https://community.graphisoft.com/t5/Wishlist/idb-p/wishlist
If you do, please post its link here.
James B
James Badcock
Thank you, James. I must have missed that button! I'm used to Keynote labels not actually being live like that.
I like it; it opens up additional opportunities to add supplemental text!
V6.5-26.0
Sorry, I see my previous answer was incorrect. I misinterpreted your post and thought you wanted to make a single Keynote out of multiple Keynotes in the Keynotes Palette.
No, I don't see the need to do that (yet). Combining multiple keys into one label was my need. Thank you both for the help.
V6.5-26.0
Setup info provided by author
