Composite Wall Issue
If there's a way to composite wall dimension only the concrete width? For example, if I'm using a composite wall with 6" concrete an 5/8" gyp. bd. but only want to dimension the concrete wall. Now I can dimension 6 5/8" and I want just the 6".
Picker the corner of the concrete wall and it will dimension 6" and a separate dimension of 5/8".
Then delete the 5/8" dimension node.
Grant
__archiben
Grant
why the long way around grant?
in the dimension dialogue box just set the dimension settings to 'dimension composite core only'!!!
(of course, ensure that your composites are set up with the cores defined correctly!)
~/archiben
b e n f r o s t
Thank you guys. Ben, your option is the best one!
