6 hours ago - last edited 5 hours ago by Barry Kelly
I have a simple composite wall with plaster on both sides and brick in between. However, in section, it doesn't show the plaster at the top. How do I get it to do this?
Before you guys tell me to turn on the wall end in the composites dialog, I already have them on.
Operating system used: Windows Windows 11 Home, AMD Ryzen 5 5600H with Radeon | 3.30 GHz | 24.0 GB RAM
5 hours ago
Composite walls only have parallel skins.
The plaster will not wrap over the top or around the ends.
You could create a complex profile wall that has plaster on the top.
