SOLVED!
How to align story name and story level into a single line?
Abdullah Chaus
In my section, the levels are so close together that their text is overlapping. I don't want to reduce the text size as then it would become unreadable when printed. Is there any workaround here?
1 ACCEPTED SOLUTION
Solution
Yves
Here is a modified copy of Built-in Story Marker that displays the text on a single line
I simply copied the 2d script from the French version that I had already modified
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
2 REPLIES 2
Solution
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Hey Yves, really sorry for the late reply. Thanks a lot for the code 🙂 It works great
Setup info provided by author
