2006-03-02
		07:50 PM
		2025-01-23
		11:31 AM
			Gordana Radonic
2006-03-02 07:59 PM
sbatchelor wrote:The only things you can copy in elevations are doors & windows within the same wall. Other than that, you cannot place any new 3-dimensional items into your model in an elevation/section view.
It seems as though there is no way to copy an object in elevation. Is this true? If you have several objects on top of each other in plan it would be great to be able to lay them out in elevation but the program seems to limit you to copying in plan (where you can't really see what you're doing) or in 3D which is somewhat cumbersome. Does anyone know of another way around this?
Thanks
2006-03-03 09:49 AM
sbatchelor wrote:Use 3D; it is not cumbersome at all after you are used to it. And, it does give you instant feedback.
Thanks
2006-03-03 09:27 PM
Djordje wrote:... best if you put a marquee around the area you're working in. It's cumbersome if you work with an entire airport terminal in the 3D window, in order to copy a column 3 times.
2006-03-04 12:01 AM
2006-03-04 08:05 AM
2006-03-04 05:55 PM
Sergio wrote:Why not?
Now, is this because I wasn't looking too carefully at all the options, or can you really not work all that accurately in 3d (vs. Section/Elevation)?
2006-03-06 05:03 PM
Djordje wrote:'tis the first I've ever heard of this. So you're saying that there's a "switch" where you can select which floor/storey new items will be placed on in 3D (nevermind the fact that I didn't think you COULD place new objects in 3D)? I thought all of the modifications that get done in 3D stay on their default floor, but if you're saying that you can "move the origin", now this sounds interesting.
...Learn to move the origin to the storey you work on...
2006-03-06 05:59 PM
Sergio wrote:AFAIK elements added in 3D will be put on the story that is current in the plan view. Not a completely logical or transparent method, but easy enough to manage. I do wish there were a way to see the element's home story in the info box though.
2006-03-07 04:31 AM
Matthew wrote:Yep.
I believe Djordje was referring to the handy practice of moving the 3D user origin to the current story's elevation.
