Create twisted roof
Hi, how can i create twisted roof or wall? What tool should I use?
Caren,
The tool most capable of controlled plastic forms in Archicad
is the mesh tool. It can do twisted roofs quite well with the
help of SEO. More problematic are twisted walls which imply
wall openings. The mesh tool cannot make holes through
the sides of a mesh. The Maxonform add-on can make
twisted forms. I have not tried it so I do not know
it's capabilities and limitations.
You might try a search using the key words "mesh and roof".
Peter Devlin
Re: MaxonForm:
http://www.graphisoft.com/products/archicad/energize9/maxonform.html
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
Djordje
Also, try GDL Toolbox (free, www.archidata.hu) and ArchiForma (www.archiforma.com)
However, your twisted walls and roofs will NOT be roofs and walls as far as ArchiCAD is concerned, they will be objects.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
