Grubenstein
Creating Working Drawing Sections
Hi All,
Interested to know opinions on everyone's workflow for creating sections. Previously I worked in Revit and Created sections straight from the model (i'e a live section) and added 2d detail onto the live section (Dimensions, notes, 2d detail items like Coursing blocks, DPC's, Cavity Trays etc). Pro's the section is live and tied to the model geometry, if storey levels need to adjust as the engineer provide steelwork details etc this can be adjusted on the elevations and sections as they are all model based. Cons you end up 'patching' model inconsistancies and DWG exports are hard work for other consultants
The office I now work in for the last 7 years is an ArchiCAD office. ArchiCAD as a lot more 2d tools than Revit. The Office here primarily uses the live section of the model as a trace reference and create independent sections out of 2d linework much like a normal CAD Section. Pros - Easier to export and the drawing looks more correct as you dont have to solve every model issue (which takes time) Cons - Takes Longer and doesnt feel like the point of the software to then just draw a 2d section.
What does everyone else do
Thanks
Kevin
3 Replies 3
JeffH
We use the live Model cut and add: fills, 2d lines and elements & all annotation directly in place.
We have pretty much gone to using complex profiles for our building shell, and putting alot of the detail into these complex profiles, which saves us some 2d work.
For our section details, we are still using the live section cut, just with a different layer combination, which has further 2d details & annotation that is hidden from the overall section.
There are some instances where fills have to be used to cover up something that doesn't clean up perfectly on these larger scale drawings.
AC24 / AC26 / AC27
Win10
Grubenstein
Thanks for that, Yes I use complex profiles for a number of requirements. Work well. Making simple Library part as well. More complex parametric libary parts unfortunately look much more complex to create than in Revit!!
Any other thoughts anyone?
Josh Verran
Hi Kevin
In a practice I worked at previously, all of our sections remained linked to the live model. We tried to model as much as was practical, but there was inevitably information that was more efficient to add in 2D, particularly where something only needed to appear in a limited number of sections.
There are a few ways you could approach that.
Favorites are probably the simplest option for commonly used 2D elements.
Another workflow we found useful was to have a dedicated
Worksheet in the template containing commonly used 2D section resources. That Worksheet was saved as a View and organised alongside the section Views in the View Map.
When working in a section, you can show that Worksheet as a
Trace Reference and use the Eyedropper to pick up elements directly from the reference and place them into the live section. Once you're finished, turn the Trace Reference off and the copied elements remain in the section. The same resource can then be used across the other sections as required.
If you wanted to develop the workflow further, you could also consider keeping those standard resources in a separate file and bringing them into the template using a
Hotlink, so the source content can be maintained centrally and updated across projects.
It can also be useful to set up a
Find & Select criteria for these 2D elements, particularly when you need to quickly identify or select them within a section. You might also consider placing this type of documentation element on a dedicated layer, which can make them easier to manage and control.
There are obviously other ways to approach it, but this worked quite well for us while still keeping the sections connected to the live model.
Josh Verran
Senior BIM Specialist, Graphisoft
Archicad templates, workflows and practical use
