2021-08-05 07:03 PM - last edited on 2023-05-26 02:20 AM by Gordana Radonic
2021-08-05 08:00 PM
another Moderator
2021-08-10 01:53 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-08-24 04:49 AM
2021-08-24 10:33 AM
Minh Nguyen
GRAPHISOFT
2021-08-24 11:38 AM
2021-08-24 01:24 PM
Minh Nguyen
GRAPHISOFT
2021-08-31 02:32 AM - edited 2021-09-02 11:26 AM
Hi Minh,
Thanks for replying to this thread. I’ve also run into this issue (DEF-5748, custom drawing titles go haywire when exporting/printing to PDF).
It’s a major problem for my practice. Imagine having multiple drawings on each sheet, and tens of sheets per project. Then multiply that by the number of projects in the office. Sure, all drawings on each sheet could be selected and changed to use built-in drawing title, but then each drawing title would then have to be repositioned. Maybe each layout would need to be adjusted as well to fit the new drawing titles.
And of course there is the issue of appearance and consistency. I think it’s reasonably safe to say that users apply custom drawing titles because they don’t like the look of the built-in ones. In my case, it’s also because it saves space on my layouts, and keeps things tidier in general. Assuming that the custom titles were swapped out for the built-in ones through the tedious process above, and assuming that the issue is eventually fixed, one would have to go through the same process across hundreds of drawings again to restore the old titles.
I had a meeting yesterday where drawings were published shortly before the meeting started. I noticed the issue with the drawing titles, but had to send them out anyway with apologies. Fortunately, the drawings were preliminary and just for discussion in this case, so it wasn’t a huge problem. However, issuing for construction would be a much more serious matter, and I have such a drawing issue coming up.
In short, I’m trying to illustrate that this is not a trivial matter for some of us, and I hope that the bug is fixed as a matter of urgency – perhaps even in the form of a hotfix.
2021-08-31 05:17 AM
2021-09-16 01:56 AM
Eduardo referred me to this page because I had the same issue (apologies for creating a new thread). I was able to solve it by using different variables. See thread here. Hope that helps.
