The labels are getting the layer of the object now. I am not sure why they were all ending up on the Annotation-Text layer.
It is only for the initial placement of the label I was concerned about. I do assign them a special layer after the initial placement and re-numbering.
It's a floor framing plan I am labeling. It was a pain to work with when all the labels kept going to the Annotation-Text layer. I would have to switch views to find it, then change the layer so it would show with the beams they were associated with.
I just did a few more and at least the labels are going to the same layer as the beams so I don't have to hunt them down. I am using ID as the label for renumbering with the Element ID Manager so I am not placing labels, I am just checking Label Beam box for some of the beams. The ones I need labeled for the engineer.
It would be convenient if we could set the layer we want the label to be on in the Tag's & Categories dialog box since we would very seldom want the labels of objects on the same layer. Why it was always placing the labels on the Annotation-Text layer I don't know. That is a default layer I an not using anyway.
