License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
Detail Marker to show layout ID it is placed on
Chris Pooley
Hi All,
I am trying to make the detail marker show the layout the view is placed on. I can manually draw write the layout ID in there, but if I add more sheets or change the order of the sheets, I would like this to automatically update.
I know this must be possible as there is a checkbox there, but I cant make it turn on.
ArchiCAD 19 to 27
Windows 11
kmitotk
Set "with Marker reference to" to "The first placed drawing  of the viewpoint".
Kei Mito
Architect | Graphisoft Certified BIM Manager
ArchiCAD 27 JPN USA & INT | Windows 10
kmitotk
Kei Mito
Thank you very much.
ArchiCAD 19 to 27
Windows 11
