SOLVED!
Detail Marker to show layout ID it is placed on
Chris Pooley
Hi All,
I am trying to make the detail marker show the layout the view is placed on. I can manually draw write the layout ID in there, but if I add more sheets or change the order of the sheets, I would like this to automatically update.
I know this must be possible as there is a checkbox there, but I cant make it turn on.
ArchiCAD 19 to 27
Windows 11
1 ACCEPTED SOLUTION
Solution
kmitotk
Set "with Marker reference to" to "The first placed drawing  of the viewpoint".
Kei Mito
Architect | Graphisoft Certified BIM Manager
ArchiCAD 29 JPN/USA/INT | Windows 11
2 REPLIES 2
Solution
kmitotk
Kei Mito
Thank you very much.
ArchiCAD 19 to 27
Windows 11
