Detect unused layers
Gisele
is there a tool that helps detect (then delete) unused layers safely?
The purge tool deleted layers that were not "empty."
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
julienK
if you go in Options> elements Attributes > Attributes manager
select the layer tab,  every  layer that  has a checkmark next to it is used. all others can be safely deleted.
1 REPLY 1
julienK
