Dimension text direction in Layout
Dear,
During the drawing of a big project I got to the strange problem. When I put a part of a project (as a drawing) in a layout and rotate it for a 90°, dimension text remains just it was at the drawing, and it is hard readable on a paper sheet (you need to rotate paper for 180° to be able to read it). Usually, with the small buildings, I was making an easy solution with rotation of whole building for a 90° before putting it on a layout... now it would be not a good solution, because all other dimension texts in whole project will not stay in right positions. Is there any option to fix that problem just for that layout?
Thanks
P.S. I am using Archicad 19
Eduardo Rolon
If I understand correctly.
The correct way to do this is to save the view with the rotation first and then place it in the layout. Use the "Set Orientation" command and when you select the view check also that under Zooming you have "Zoomed Area" selected as part of the settings.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Wow! Thank you! That was huge help!
