‎2016-08-12
11:18 AM
‎2023-05-19
03:53 PM
Gordana Radonic
‎2016-08-12 02:41 PM
another Moderator
‎2016-08-16 08:37 AM
ejrolon wrote:Wow! Thank you! That was huge help!
If I understand correctly.
The correct way to do this is to save the view with the rotation first and then place it in the layout. Use the "Set Orientation" command and when you select the view check also that under Zooming you have "Zoomed Area" selected as part of the settings.
