ChrisStow
Dimensions disappearing in section on saved view on layout
Hello AC community,
We have created a very simple section through a building.
The saved model view (image can be seen below) we have included a string dimension for the floors / ceilings etc. When placing the view on the layout the dimension arrows aren't appearing correctly and on some sections disappear altogether.
Has anyone seen this bug or have any suggestions / work around to get the arrows & dimensions appearing correctly.
Many thanks for reading.
Chris S
CSP Architects
Archicad 25 (4013 UKI FULL)
Windows 10 Pro
Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz 4.00 GHz
RAM 32.0 GB
Section dimesnion markers view in model.jpgSection dimesnion markers view saved on layout.jpg
Regards,
Chris S
Version: Archicad 25 (6000 UKI FULL)
Operating System: Windows 10 Pro
Processor: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz 4.00 GHz
RAM: 32.0 GB
CSP Architects
www.csparchitects.co.uk
1 Solution
ChrisStow
Hi Noemi,
I think it is a different topic... we have had a solution for our particular query thankfully.
Arrow size was the problem as described in the article below.
 https://community.graphisoft.com/t5/Collaborate-forum/Archicad-25-Teamwork-migration-dimension-bug-o...
Regards,
Chris S
RAM: 32.0 GB
CSP Architects
Go to post
3 Replies 3
Noemi Balogh
Chris, can you check if this is what you experience? https://community.graphisoft.com/t5/Teamwork-articles/Dimensions-Display-Inconsistently-Among-Teamwo...
Might give you useful tips how to workaround the problem.
Noémi Balogh
Staff Community Expert, Admin
ChrisStow
Thanks for the reply Noemi really appreciated.
I have tried runnning through the options on th article with no joy i'm afraid. There is another article linked below which suggests there is a known bug which the developers are aware off the issue.
I have contacted Graphisoft support as it is a big problem for us.
Thanks again.
Regards,
Chris S
RAM: 32.0 GB
CSP Architects
ChrisStow
Hi Noemi,
Regards,
Chris S
RAM: 32.0 GB
CSP Architects
