2008-12-31
09:02 AM
2023-05-30
03:17 PM
Rubia Torres
2008-12-31 06:33 PM
Wrathchild wrote:Even though accurate model building is the "always" the goal, one missed snap either in building or dimensioning and there it is. And sometimes if you're building with real material dimensions it can happen. As a final check I put it in 1/64" and adjust the model to get the right dimensions. That way the dimensional creep visits less often.
I don't really think my model could be the problem. I almost always (if not always) type in exact units when laying out my plans.
2008-12-31 06:41 PM
Dave wrote:I can't imagine not using real material dimensions. That seems like asking for trouble.Wrathchild wrote:Even though accurate model building is the "always" the goal, one missed snap either in building or dimensioning and there it is. And sometimes if you're building with real material dimensions it can happen. As a final check I put it in 1/64" and adjust the model to get the right dimensions. That way the dimensional creep visits less often.
Dave
2008-12-31 09:57 PM
Wrathchild wrote:I agree, but the point is, let say you have 15/32" actual sheathing and inadvertantly snap to it rather than framing line (either in dimensioning or placing) then depending on your offset you can come up with dimensions that are off by some small amount which show up as a 1/64" when dimensioned at that setting or give the strings that do not add up at a higher setting.
2008-12-31 10:12 PM
2008-12-31 10:21 PM
2009-01-02 06:31 PM
Karl wrote:This is our practice. Also keep in mind construction tolerances -- accuracy is crucial, but allow for "creep".
I would use accurate sizes for everything, including that 15/32 sheathing. One should not be snapping to wall skins for dimensioning if using complex walls IMHO, but should be using 'core' dimensioning, which is handled by clicking on a wall edge and letting ArchiCAD find the core. You end up having to delete some extra dimension points to clean up, but it saves problems.
Like Lew, I also recommend always working in 1/64 working units, and 1/64 working dimensions. Use some lower rounding dimension for your placeable views.
2009-01-04 05:31 AM
2009-01-05 05:21 AM
2009-01-05 04:45 PM
Erika wrote:Our practice is to omit the last (or least critical) dimension -- to never close a dimension string.
An old-school technique was to put in a long string a +/- on one dimension to show where you the architect would allow these rounding errors to be resolved.
2009-01-05 11:27 PM
