i am having disappearing dimension problems of another sort. finally chased down what was up.
dimensions done using 'entire model' partial structure view settings do not show when using show 'core only' even when dimns are core only. also cannot copy dimn, put it on a different layer and get it to show.
i need a construction layout plan that does not show the thick 3" ext insulation and gyp board but does show all the walls, door and window centerlines. thought i could easily toggle between these settings with out punishment.
i have read the help area regarding dimns and partial structure but it does not help now. file:///Applications/Graphisoft/ArchiCAD%2015/Help/Files/wwhelp/wwhimpl/js/html/wwhelp.htm
"Dimensions in Partial Structure Display
Dimensions are connected to the Partial Structure display setting: each Partial Display mode has its own set of dimensions: you can have a set of dimensions in your Core Only view, and other sets of dimensions in your Entire Model and Without Finishes views. If you switch between Partial Structure Display settings, the dimensions associated with the earlier Display setting will not be visible. To see the Dimensions again, switch back to the Partial Structure Display setting in which the Dimensions were placed."
it would be great to have known this much earlier in project. i do not consider this a feature but a nasty bug. at least i finally chased it down to show partial structure settings. is this 'feature' still in v16?!
how many other fantom setting are there that come back and bit you on the ass. guess you can see i am pissed off sitting inside dealing with this cr*p rather than being outside on a beautiful day.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
