ā2013-11-02
08:30 AM
ā2023-05-26
02:12 AM
Gordana Radonic
ā2013-11-02 09:39 AM
ā2013-11-02 10:01 AM
zeropointreference wrote:Hi, thanks soo much for the reply. the settings there seem fine (photo below) but the labels still don't show up.
I'd check your Documents>Set Model View>Model View Options. You can override things like fills and markers with model views.
ā2013-11-03 07:32 AM
ā2013-11-03 11:20 AM
ā2013-11-04 09:40 AM
zeropointreference wrote:How do I do that?
Did you make sure to set that model view as active?
And the reno filter that shows markers as active?My renovation filters don't see to have a show/hide option for markers. I'm sure I am missing something here. I'm looking at the drawings in "Planned status"
As well as to make sure that your saved views in the View Map have had their view settings adjusted to show the right renovation and model view options?Again, I have no idea how to do that.
Outside of those two things all I can think of is having two walls in the same spot with one wall having markers onno such case
and the other off as well as layer combinations that would hide one wall while showing the other in order to control markers showing,I'm trying different combinations here but no cigar.
Edit: One other thought is your library isn't loading up right and the markers you have selected are missing library parts?I'm using the 'standard' circular markers, edited in the options to just show door and window ids. Is there a way to check if anything is not loading up?
ā2013-11-04 01:03 PM
ā2013-11-04 01:08 PM
ā2013-12-27 10:29 PM
