Drawing Index: Fine for layout book but what about publish set?
Aurasphere
So much great work done over the years for publising'
Im just wondering how the project drawing index can accurately present published outputs as they are often reassembly of a master list?
Or at least have context sensitivity so that if they arent on this publish set, they are hidden in list
Mark Wesse
AC26 | Win10 | Since v6.5r
Architerion - Architectural Systems Developer
Aurasphere - Acoustics
Building Biology - Human Compatible Architecture
"--- Every time...do it better ---"
1 REPLY 1
aarkell
It may not be automated, but one way to filter a drawing sheet index is to create a new parameter in your book settings, under Layout Info Scheme. Your sheet index schedule could then be set to show only sheets with an "X" under the created parameter, for example. You could therefore have multiple scheme settings created for each publisher set or, alternatively, you could have a sheet index that shows all issuances and displays an "X" for applicable issuances. Similar to the screenshot below.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
