Drawing displaced on layout
Several people in my office have this problem. It's simple but we just can't find the cause of it. Often when we want to place a new drawing on the layout it is displaced miles away from the actual layout. So we need to zoom out, find a little dot on the screen that represents the drawing, drag it back to the layout and zoom in back again. Any ideas why this happens?
14 Replies 14
You are absolutely right, Kimfrromzim, it's the project origin that matters not the user origin. I haven’t realized this. And the reason why it’s so displaced is that I started the project by opening an existing DWG survey saved it as ArchiCAD file and just continued to work on it. Thank you Djordje for pointing out what the problem might be.
I used to share an office with Djordje, and the number of times we got DWGs with project origin miles away - in fact I think we always did, there was never a time when the origin was actually in the same place as the drawing that they produced...and we had to move the whole lot over to the origin, if it would even open when the origin was so far away.
I learnt some Serbian curses in those days ... 😉 which as a lady I've forgotten now, of course!
Off-topic:
Did you guys notice that Kim's Avatar winks?
It happens about every 6-7 seconds.
(Maybe it is an animated GIF)
Djordje
Around here, the Autocad using majority does not know ANYTHING about origins, limits, etc ... line, offset, trim ... aaaargh!
No, you can't correct them as you would be doing nothing else!!!!
I also have the same problem when I do as Akos did - start from a DWG. Then the shooting off to space is inevitable.
Completely off topic: I have the privilege of all three of being my dear friends that I have met personally!!!! Never mind the 5000km to Budapest, or "a bit" more to Winchester ... and yes, Kim does wink so ladylike 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
hello everybody,
just started with AC 12 and i'm having the exact problem described above.
Have any solutions appeared since the original post?
thanks in advance..i'm goin nuts with this 😃
