2017-10-13 11:43 AM - last edited on 2023-05-26 12:03 AM by Gordana Radonic
2017-10-13 01:34 PM
2017-10-13 02:49 PM
Erwin wrote:It is rotated view, but the rotation is exactly same in every story. If I open a view, then change the story in project map, then save new view, shouldn't it be similar in every possible setting than the view I opened first? Still it rotates the second view on the layout.
Maybe the view is rotated by Set Orientation, this can be saved to individual views.
2017-10-13 04:35 PM
2017-10-17 09:56 AM
Erwin wrote:Yes, I know that. Rotation is same in every view, so that is not the reason in this case.
Rotation is saved for each individual view, it is not related to your project map or different stories.
By default views are not rotated.
