russfairhurst
Editing in sections requires rebuild to see changes
I am editing building elements in sections, and after edits the item dissapears and the section needs to be rebuilt to see the change. This has been happening in every release of AC28. Is there a setting that I can change, or is this just how it is now? 
Archicad 27 below-edit wall height.
Now in Archicad 28- edit wall height. Wall dissapears and requires a rebuild for it to show the change.
Versions 6.5 to 28
Windows 11 Intel Core i9-13900K RAM 128GB NVIDIA GeForce RTX 4090
1 Solution
kuvbur
Did you check Auto-Rebuild Model View Control in Options > Work Environment > Model Rebuild Options?
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Go to post
5 Replies 5
Aaron Bourgoin
have you looked at your section settings? Specifically the Section Status. See image attached.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.1.0 USA
Rhino 8.30 Mac
MacOS Tahoe 26.4.1
russfairhurst
No, thats not it. Is this just happening to me? Can someone confirm that they are not having this issue with Archicad 28?
Versions 6.5 to 28
russfairhurst
Tested with a new and reset, and the section updates as expected.
Could this be an issue with a job file that has been started in an earlier version and has been moved up to AC28?
Versions 6.5 to 28
kuvbur
russfairhurst
That was it. Thanks kuvbur
Versions 6.5 to 28
