CYNZ
Elements not showing in section view
I am having an issue with elements not showing in section view. All the solutions provided in posts I have see don't seem to fix the issue.
I have checked:
Renovation filters
Layer combinations
Any ideas?
Thanks
6 Replies 6
Lee Hankins
Which elements aren't showing? Have you checked Model View Options? Which version of Archicad are you using and on which OS?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
CYNZ
I'm using Archicad 24 student edition - Windows 11 Pro (21H2)
Its a number of elements - Columns, stairs, plumbing fittings, some exterior walls
CYNZ
I have checked the model views and they seem ok.
Please see attached the floor plan and the section incase they help in any way.
Lee Hankins
Have you tried turning all layers on to visible. I know you mentioned you had checked layer combinations but it would be worth a try. It would be useful to post some screenshots of the section, the section settings and a 3D view to see if the elements appear there.
Lee Hankins
macOS Tahoe (26.0)
Lee Hankins
Is the section set to zero depth in the section settings? If it is try setting it to infinite or set depth.
Lee Hankins
macOS Tahoe (26.0)
ksjhawk
Any chance you'd be willing to share the model? It does look like a zero depth section. You may be right Lee.
MacBook Pro Apple M4 Max 128GB ram
OS X 15.7.2
AC29 - AC6.5
