2023-10-05 08:22 PM
Is there a way to purge empty layers? Is there a method that permit to export a pln as a pln excluding empty layers?
Solved! Go to Solution.
2023-10-06 04:06 AM
You can purge unused attributes in the Attribute Manager.
Be sure to 'save as' to another file if you want to keep the original with all of its attributes.
Or saving as a module (.MOD) file only saves the file with the used attributes.
This will have just the plans and 3D model - not sections or elevations, etc.
2023-10-06 04:06 AM
