External drawings on layout
Hello everyone,
I have some layouts with external drawings on them. Now everytime I re-open the file I have to update the external drawings manually before they become visible on my screen, also with publishing they remain invisible untill I manually update them. The settings for the external drawing are already on automatic update, but this does not seem to help.
Does anyone know a solution for this?
Thanks in advance,
Stijn
Erwin Edel
We prefer to publish views to PMK from the source file and link those in the layouts instead. It gives you a bit more control over which linked views you want to update and it is a lot faster in terms of updating. You lose the 'live' connection though.
If the external drawings are not ArchiCAD drawings, you can tick a box to store them in your PLN.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
For mass updating, I recommend using the Drawing Manager.
www.leloup.nl
