Fill in cavity w/o fill?
architect
Any way to avoid using a gray fill to get a solid gray ceiling/roof cavity?
It's tricky with trusses as the spaces in between webs/chords are empty.
I drew the Truss as a complex profile.
Then settings for the gaps as follows:
Still allows a 3D-appearing truss.
Marc H
How about cutting your section through the truss?  That would provide solid cut fill for the truss.  For the insulation section, you can apply a GOR for gray.
As to the non-insulated truss voids, do you need those really need to be filled in?  That will block your dimensions and notes within.  But if so, perhaps a normally clear material plane placed in line with the truss cut (along the section line) that can also be subject to a cut fill or GOR?
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Setup info provided by author
