GRAPHIC Overrides
mukster
Archicad 27 on a MAC platform. For some reason, all my beams are solid pink. I tried looking at all the graphic 0verrides, and all the different settings don't help.
Hi Mukster,
I can think of two other possible issues:
  1. Some building material / composite / surface / texture is missing
  2. If the beam is actually a wall or column element it's height could be inverted. (See: https://community.graphisoft.com/t5/Modeling/Pink-Walls/td-p/163922)
mukster
It was the Work Environment/On Screen options
Josh Verran
When you hover over an element, if a Graphic Override is affecting it, it should show up as highlighted below.
That might help isolate the rule.
As mentioned above, if there's no rule affecting the element, it could be missing attribute, although this normally shows as black and pink checkers.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
