2024-02-17 12:24 AM - last edited on 2024-02-17 09:18 PM by Laszlo Nagy
Archicad 27 on a MAC platform. For some reason, all my beams are solid pink. I tried looking at all the graphic 0verrides, and all the different settings don't help.
2024-02-17 01:37 PM
Hi Mukster,
I can think of two other possible issues:
2024-02-20 06:20 PM
It was the Work Environment/On Screen options
2024-02-20 10:34 PM
When you hover over an element, if a Graphic Override is affecting it, it should show up as highlighted below.
That might help isolate the rule.
As mentioned above, if there's no rule affecting the element, it could be missing attribute, although this normally shows as black and pink checkers.
