2024 Technology Preview Program
GRAPHIC Overrides
mukster
Archicad 27 on a MAC platform. For some reason, all my beams are solid pink. I tried looking at all the graphic 0verrides, and all the different settings don't help.
Hi Mukster,
I can think of two other possible issues:
  1. Some building material / composite / surface / texture is missing
  2. If the beam is actually a wall or column element it's height could be inverted. (See: https://community.graphisoft.com/t5/Modeling/Pink-Walls/td-p/163922)
Bernd Schwarzenbacher - Archicad Add-On Developer - Get Add-Ons & Archicad Tips on my Website: Archi-XT.com
mukster
It was the Work Environment/On Screen options
Josh Verran
When you hover over an element, if a Graphic Override is affecting it, it should show up as highlighted below.
That might help isolate the rule.
As mentioned above, if there's no rule affecting the element, it could be missing attribute, although this normally shows as black and pink checkers.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Perth, Australia and Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
